Oldie
(128)
  • "Oldie" started this thread
Occupation: Pensionist
Saturday, June 27th 2015, 9:49pm
Güllewagen
Gibt es ein Hersteller von Anlagen für die Landwirtschaft? :)
Tim
Pottendorf
Ich spreche kein Deutsch, deshalb verwende ich eine Maschine. :S
Holsteiner
(20)
Occupation: Kraftfahrer
Sunday, June 28th 2015, 9:53am
Hallo Tim,
Güllewagen bekommst Du bei:
www.modellbahn-engl.de
www.shapeways.com
Gruß Thorsten
Sunday, June 28th 2015, 10:47am
Hello Tim.
Quoted
I had searched for some of these items - as we talked about at our meeting on wednesday.
For your information:
  • Güllewagen
  • Jauchewagen
  • Odelwagen (more common in southern Germany and Austria)
are the translations of what you are looking for.
But unfortunately I found no solution in your direction.
As Thorsten mentioned there is a nice detailed item available at shapeways from Henrik Werner (forum member).
http://www.shapeways.com/product/LJUZCF3…tionId=42454024
it's used both for water OR slurry.
In the low cost area the only items I found were newer types (with twin axles and bigger drums), not the style of Ep. III
In H0 scale Preiser has a fine solution:
http://www.preiser-figuren.de/shop.php?s…bac7e34&lang=de
Kind regards
dry
This post has been edited 3 times, last edit by "dry" (Jun 28th 2015, 10:54am)
Schlußscheibe
(34)
Occupation: Dipl.-Ing.
Sunday, June 28th 2015, 5:50pm
Hello Tim,
you could convert a military airfield fuel truck. They should be available as plastic kits in 1/48 scale.
German farmers often did it the same way - take an old lorry, remove engine, gearbox, front axle and driver's cab, bend the outer girders of the underframe so that they meet with their front ends, install the eye for the coupling and the jockey wheel.
Kind regards,
Schlußscheibe (End-of-train-disc...? - that little red-white reflecting sign at the end of german freight trains ;) )
Robby
(285)
Sunday, June 28th 2015, 7:06pm
Ich möchte auch gerne wissen, was da geschrieben wird. ?(
Ich kann nämlich kein Engländisch !!!!
Ich kann nur Französisch, da habert es aber an der Sprache. :D :D
Gruß Robby
Sunday, June 28th 2015, 8:02pm
Hallo Robby
Quoted
Zusammenfassung -> Summary
Tim interessiert sich für Anbieter von Gülle-, Jauche-, Odelwagen (Odlwagen(?)).
Dies hat er mir auch am Mittwoch erzählt, als wir uns trafen - und fragte nach den entsprechenden (deutschen) Begrifflichkeiten für eine googlesuche.
Er hatte auch noch die Idee etwas aus dem Spielzeugbereich zu verwenden - ich fand da aber nur neuere Dinge - keine Epoche III geeigneten Modelle. Letztendlich hab ich ihm den von Torsten bereits erwähnten Jauchewagen von Henrik empfohlen.
Die Schlußscheibe empfahl ein Modell aus dem Militärbereich in 1:48 zu suchen und dies abzuändern, so wie es die Bauern (Farmer) auch getan haben.
und so übersetzt seinen Beitrag der goolgeübersetzer (den Du auch hättest zu rate ziehen können):
Sie könnten eine Militärflugplatz Tankwagen zu konvertieren. Sie sollten als Kunststoff-Kits zur Verfügung stehen in Maßstab 1:48.
Deutsch Bauern oft hat es die gleiche Weise - nehmen Sie einen alten Lastwagen, entfernen Motor, Getriebe, Vorderachse und Fahrerhaus, biegen Sie die Außenträger des Untergestells, so dass sie mit ihren vorderen Enden zu erfüllen, installieren Sie das Auge für die Kupplung und der Jockey Rad.
in diesen Sinne "hope this helps" - hoffe es hilft
zum Verständnis dieser völkerverständigenden Diskussion - auch wenn sie zweisprachig geführt wird.
In diesem Sinne 2 (an Tim): you are welcome!!
Sei willkommen!!
Gruss dry
This post has been edited 1 times, last edit by "dry" (Jun 28th 2015, 10:51pm)
Baumbauer 007 (28.06.2015), Robby (28.06.2015), Udom (29.06.2015), Knut2705 (29.06.2015)
